[GRASSLIST:22] Re: what to use instead of s.cellstats?
Téglásy Örs orsteglasy at yahoo.com
Sun Mar 12 02:44:53 EST 2006
Hamish, thank you for the answer! One more question: is it possible to install Grass 5.4 on the same machine while having grass 6.0 already on it? Should it cause any trouble? Sorry for the question, but I'm coming from the microsoft universe ;-)
  Thanks!
  Örs
Hamish <hamish_nospam at yahoo.com> wrote:
  > I have a grid of sites. I would like to sum up the values of these
> sites hundred by hundred. According to a grass article I should be
> able to do this using s.cellstats -sum command but it doesn't exist
> any longer under Grass60. Any idea what to use instead of it?
GRASS 5.4 still works fine, load the data into there, use s.cellstats,
then restart in GRASS 6 and use the new raster map. Raster maps are
backwards compatible, you may need to edit out any 3D lines in the
mapset's WIND file if you want to go GRASS 6 -> GRASS 5.
Hamish
  Kontakt:
  Téglásy Örs
+36 (20) 385-5928
Yahoo! Mail
Bring photos to life! New PhotoMail  makes sharing a breeze.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060311/981e172f/attachment.html
