[GRASSLIST:178] Re: Question about re-projecting points imported from Postgres
David Finlayson david.p.finlayson at gmail.com
Thu Mar 16 13:33:18 EST 2006
Ah, I understand now. I'm afraid I can't help you with this. I've only
used databases to hold attribute information not the topology also. I
haven't tried PostGIS yet.
David
On 3/15/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> List:
> I have a Lat-Long location into which I have successfully imported
> points from Postgres (a further question about this further below). What
> I want to do is to re-project the points into a Lambert Conic Conformal
> location using v.proj. When I try to do this, it does not work — it
> seems as though GRASS does not know how to do this. I have been able to
> do this successfully with points imported using v.in.ascii. It seems I
> am missing something, either conceptually or procedurally…
> The further question about using v.in.db, the 'key' parameter in the
> documentation claims this is a string, which makes since to me, but when
> v.in.db is run, GRASS complains that an integer is needed. I'm guessing
> the integer that's supplied is the column/field number (beginning with
> '1'); if true, this seems to be inconsistent by what the 'x', 'y', and
> 'z' fields require — just a thought.
> Tom
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL:  thomas.adams at noaa.gov
> VOICE:  937-383-0528
> FAX:    937-383-0033
David Finlayson
