[GRASSLIST:203] Re: making a "true-color" landsat composite
maning sambale emmanuel.sambale at gmail.com
Fri Mar 17 04:45:35 EST 2006
two things:
1.  simple label mistake on the GUI (see attached)
2. erros below.  Im using huidae's binary on cygwin running on XP.
i.landsat.rgb blue=tm2001_7 green=tm2001_4 red=tm2001_2 output=test
Sorry, <per> is not a valid parameter
Description:
 calculates univariate statistics from a GRASS raster map
Usage:
 r.univar.sh [-e] map=string
Flags:
  -e   extended statistics (quartiles and 90th percentile)
Parameters:
  map   Name of raster map
Description:
Usage:
Flags:
Parameters:
syntax error, unexpected ','
Parse error
Cannot find tm2001_7.nice
tm2001_7.nice - map not found
Description:
Usage:
Flags:
Parameters:
Description:
Usage:
Flags:
Parameters:
Parse error
Cannot find tm2001_4.nice
tm2001_4.nice - map not found
Description:
Usage:
Flags:
Parameters:
Description:
Usage:
Flags:
Parameters:
Parse error
Cannot find tm2001_2.nice
tm2001_2.nice - map not found
Cell layer [tm2001_2.nice] does not exist
Created raster map <test>
On 3/15/06, Markus Neteler <neteler at itc.it> wrote:
> Glad to hear that i.landsat.rgb works well.
> I sort of hesitate to add it to CVS since it could be
> "easily" added to r.colors.
> I cc to grass-dev to seek for a solution. The only
> real missing function in the C library is the possibility
> to calculate percentiles from a channel histogram.
> Wolf was working on that (percentiles in r.univar) but
> apparently it's not complete. The approach could be:
> - implement percentiles and related stats in C (gmath?)
> - add percentiles to r.univar
> - add percentiles to v.univar
> - remove r.univar.sh as no longer needed
> - remove v.univar.sh as no longer needed
> - implement method in r.colors (the LANDSAT color trick is
>   to take away 2% of the histogram area from top and bottom)
> Having this long term wish "percentiles" implemented in C
> would in fact solve a couple of problems (duplicated modules).
> I really hope that we can find another capable to help Wolf
> (if he's still available).
> Markus
> On Wed, Mar 15, 2006 at 12:12:23AM -0800, Dylan Beaudette wrote:
> > Thanks again Markus:
> > your new i.landsat.rgb script did wonders on these images!
> > examples:
> > original made with r.composite:
> > http://casoilresource.lawr.ucdavis.edu/drupal/node/217
> > new one made with i.landsat.rgb:
> > http://casoilresource.lawr.ucdavis.edu/drupal/node/216
> > Cheers!
> > Dylan
> > On 3/14/06, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> > > Ian,
> > > Thanks for the pointers. In the past, I was not performing any
> > > "enhancements"
> > > to the landsat scenes as there were so many of them, and they looked good
> > > enough. However with Markus' latest script, I think that I will re-compile
> > > arizona! good thing that I hadn't started on Nevada yet!
> > > Cheers,
> > > Dylan
> > > On Tuesday 14 March 2006 12:44 pm, Ian MacMillan wrote:
> > > > Dylan, I am not sure if you have this problem, but you might want to
> > > > watch out with the colors when you patch landsat tiles together.  The
> > > > colors tend to get screwy since the the shots were each taken at
> > > > different times of day, different days of the year, etc.  I have found
> > > > that it is best to enhance each tile separately, then patch them
> > > > together at the end, rather than patching all band 1's, all band 2's
> > > > etc.  You probably already knew this, but thought I would add my two
> > > > cents.
> > > > -Ian
> > > > On Mar 14, 2006, at 10:04 AM, Dylan Beaudette wrote:
> > > > > Markus,
> > > > > Nice images!
> > > > > a couple things:
> > > > > 1. the link at the top of the page had some interesting polar plots.
> > > > > For hard copy I found that ps.rose in the GMT suite produces excellent
> > > > > results as well:
> > > > > http://169.237.35.250/~dylan/NPS/day100.png
> > > > > 2. the color boost technique -- is your script available on the GRASS
> > > > > wiki somewhere, or in the grass scripts dir in a recent CVS branch?
> > > > > This looks like it will do the trick, now the only problem is that I
> > > > > have just put together the entire state of Arizona with the poor
> > > > > looking imagery!
> > > > > thanks for the tips,
> > > > > Dylan
> > > > >>> Hi everyone,
> > > > >>> I was working on constructing some "true color" landsat composite
> > > > >>> images today
> > > > >>> from bands 3,2,1 -- and came across some strange inconsistencies.
> > > > >>> Data from
> > > > >>> one source produces "nice" true color images:
> > > > >>> http://casoilresource.lawr.ucdavis.edu/drupal/node/211
> > > > >>> whereas, another source produces somewhat muddy true color
> > > > >>> composites. I tried
> > > > >>> playing a bit with an equalized grey colormap for each band via
> > > > >>> r.colors
> > > > >>> color=grey.eq with the following results:
> > > > >>> http://casoilresource.lawr.ucdavis.edu/drupal/node/215
> > > > >>> Does anyone have any tips on how to tweak color ramps for the
> > > > >>> various bands so
> > > > >>> as to get a better looking "true color" composite?
> > > > >> how do you like this LANDSAT:
> > > > >>  http://mpa.itc.it/markus/grass61/demos/
> > > > >>  -> LANDSAT 7 color boost
> > > > >> Markus
> > > > This message has been scanned by Postini anti-virus software.
> > > Dylan Beaudette
> > > Soils and Biogeochemistry Graduate Group
> > > University of California at Davis
> > > 530.754.7341
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |Philippine Biodiversity Web Map                           |
| _)_/LI  |www.geocities.com/esambale/philbiodivmap/philbirds.html   |
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060317/af53b940/ilandsatrgbwin.jpg
