[GRASSLIST:361] G_gisinit
Ana Soares tiobrothercamarada at gmail.com
Fri Mar 24 09:51:08 EST 2006
Hello
I've a problem : I use G_gisinit but I'm having some trouble understanding
it
>From what I've read :
 int G_gisinit (char *program_name)initialize gis libraryThis routine reads
the user's GRASS environment file into memory and makes sure that the user
has selected a valid database and mapset. It also initializes hidden
variables used by other routines. If the user's database information is
invalid, an error message is printed and the module exits. The *program_name
* is stored for later recall by *G_program_name.* It is recommended that
argv[0] be used for the *program_name
*Ok.
*So I use it  in my program, like :
* int main(int argc, char **argv) {
   G_gisinit(argv[0]) ;
And the program just stands there :-S
I'm really confused! After all, what does this function do ? How am I
supposed to use it?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060324/0ffe5d24/attachment.html
