[GRASSLIST:365] Re: Getting started with sqlite3 in Grass
Markus Neteler neteler at itc.it
Fri Mar 24 10:35:34 EST 2006
Eric,
try
g.manual sqlite
which should show you a help page. I have added it recently,
it should be extended.
It can be also seen via
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/db/drivers/sqlite/sqlite.html?rev=HEAD&content-type=text/html
Markus
On Fri, Mar 24, 2006 at 10:46:13AM -0400, Patton, Eric wrote:
> Can anyone provide advice on how to get up and running with sqlite3 in
> Grass? I've got it freshly installed and compiled into today's cvs. Can I
> still use dbfs or do they have to be covnerted into some other format for
> use in sqlite? The WIKI provides examples on connecting to tables through
> every other db driver except sqlite.
> Thanks,
> ~ Eric.
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
