[GRASSLIST:410] Re: v.clean and snap feature...
Patton, Eric epatton at nrcan.gc.ca
Mon Mar 27 06:32:28 EST 2006
Hm, weird I tried to re-create Luca's problem and couldn't. I made two lines
similar to Luca's below and managed to snap the vertices at a number of
distances, even when the unbroken parallel line was closer than the two
vertices. (?)
Do both lines belong to the same vector/layer?
~ Eric.
-----Original Message-----
To: Luca Casagrande
Cc: GRASSLIST at baylor.edu
Sent: 3/25/2006 10:20 PM
Subject: [GRASSLIST:383] Re: v.clean and snap feature...
> I have got a vactor line layer with a lot of line splitted; in v.digit
> they  look like this (x is red):
> -------x        x---------
> If i use the v.clean command with snap feature, the vertex are being
> snapped  on the near line and not each other.
> Is there a way to issue snap only between nearest vertex?
v.extract only the broken bits, then v.clean, v.patch?
Hamish
