[GRASSLIST:411] Re: SRTM coastline sharpening
Patton, Eric epatton at nrcan.gc.ca
Mon Mar 27 06:34:57 EST 2006
Maybe I'm not understanding the question, but couldn't you just make a
raster mask like this:
g.region <to-whatever-you-want>
r.mapcalc Newmap='1'
g.rename Newmap,MASK
~ Eric.
-----Original Message-----
To: Luigi Ponti
Cc: grasslist at baylor.edu
Sent: 3/25/2006 11:36 PM
Subject: [GRASSLIST:386] Re: SRTM coastline sharpening
> Following the GRASSNews_vol3 article on SRTM import, I was trying to
> sharpen coastlines using GSHHS shapefiles. However, the imported GSHHS
> vectors are just lines and not areas. Therefore I do not know how to
> generate a raster MASK, because there is no area for v.to.rast to
> produce a filled raster coverage.
others have mentioned the new SRTM v2 so I'll leave that, but for the
general vector how-to question:
An area is made up of a boundary and a centroid, so two steps are
needed:
# convert lines to boundaries
v.type line,boundary
# add centroids
v.category op=add   # ?!!!
This second part I know possible, but I forget the correct command.
Maybe it is v.build or v.clean?
Hamish
