[GRASSLIST:417] Re: v.clean and snap feature...
Radim Blazek radim.blazek at gmail.com
Mon Mar 27 09:18:54 EST 2006
On 5/27/06, Luca Casagrande <luca.casagrande at gmail.com> wrote:
> Alle 07:49, lunedì 27 marzo 2006, hai scritto:
> > I don't think so. It should not be difficult to write such function.
> > If you don't want to program you can put points on nodes (v.net)
> Ok done...now i have got a points vector layer with all the nodes of my
> network.
> > then extract only tho points with one line (v.net, v.extract)
> don't understand this part...I have read the v.net manual and i think that is
> the report flag to use it, but don't understand what is it for..
> > and then connect the points under certain treshold (v.distance link=)
> > and patch back.
> What is the link option?
> Reading through the manual, i found this:
> v.distance -p from=punti_estratti to=linee_spezzate out=connections
> upload=dist column=dist
I was wrong, it is called output not link.
Radim
> Thx for all
> Luca
> > Radim
> "E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
> Pascal)."
> GENTOO-GIS Development Team
> jabber: casagrande at jabber.linux.it
