[GRASSLIST:423] Re: v.clean and snap feature...
    Patton, Eric
    epatton at nrcan.gc.ca
    Mon Mar 27 10:26:25 EST 2006
Ok, now I've been able to re-create the same error as Luca. I've attached a
tiny sceen capture of the lines I used labelled with topology. The red lines
and labels belong to the original lines before snapping, the black
afterwards. As you can see, the bottom red line had nodes only on the
endpoints of the line, so that doesn't explain what happened. The only
workaround I can think of is to extract the parts of the lines you don't
want any snapping to occur on into another vector. Not really satisfactory
for a lot of edits, though.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: grass list
Sent: 3/27/2006 9:45 AM
Subject: Re: [GRASSLIST:410] Re: v.clean and snap feature...
> Hm, weird I tried to re-create Luca's problem and couldn't. I made two
> lines similar to Luca's below and managed to snap the vertices at a
> number of distances, even when the unbroken parallel line was closer
> than the two vertices. (?)
does your unbroken line have nodes near the broken ends? if so, maybe
Luca's solution is to connect line segments along unbroken line first?
Hamish
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060327/5b350cbc/Line_snapping.obj
