[GRASSLIST:494] Re: NVIZ error
Wolfgang wollez at gmx.net
Fri Mar 31 02:57:44 EST 2006
Hello,
I also found this message:
NVIZ has not been built with MPEG output support
so it's getting clear why it is not working ;-(( Is compiling NVIZ as
difficult (for a beginner) as compiling Grass? What do I need do do? Or
are there other ways to combine the rendered key frames to a movie?
Wolfgang
Glynn Clements schrieb:
> Wolfgang wrote:
>> I tried to export a keyframe animation to an mpeg file but I got this error:
>> Error: gsd_init_mpeg failed to initialize MPEG stream
>>      while executing
>> "Ninit_mpeg $animBaseName"
> gsd_init_mpeg() should write its own error messages to stderr; check
> the terminal window for one of the following:
> 	codec not found
> 	could not open codec
> 	Cannot open file for output
