[GRASSLIST:509] Re: v.in.dxf updated
Laurent C. lrntct at gmail.com
Fri Mar 31 07:09:55 EST 2006
2006/3/31, Huidae Cho <grass4u at gmail.com>:
> Hi,
> I have updated v.in.dxf to support LWPOLYLINE and TEXT
> objects.  LWPOLYLINE was
> introduced after DXF R10, so the chance is good that newer DXF files will
> be
> imported.
> One problem with TEXT is that the module actually creates points and
> attaches
> text labels through the "label" field in the linked table.  Created tables
> will
> have two fields: cat (integer), label (varchar(256)) and TEXT will be
> stored in
> the label field.  Since the label is actually not a graphic object in this
> case, rotation of text and the label box (cannot determine the dimension
> of
> label) are not supported.
> Linking labels and objects is not implemented.
> Huidae Cho
Hello,
Maybe text angle could be stored in a field  too.
Laurent
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060331/0a97bc7e/attachment.html
