[GRASSLIST:511] Re: GRASS test suite
Radim Blazek radim.blazek at gmail.com
Fri Mar 31 07:19:13 EST 2006
On 3/31/06, "Sören Gebbert" <soerengebbert at gmx.de> wrote:
> Hi Radim,
> many thanks for this info, that sounds very promising!
> With those tools, the test suite should run. If not, i will make
> it run!
> Maybe i only need to rename some progs and stuff (awk -> gawk).
> And HURRAY, md5sum is present. :)
> > MSYS includes:
> > basename.exe  env.exe      install.exe       od.exe     tail.exe
> > bzip2.exe     expr.exe     install-info.exe  patch.exe  tar.exe
> > cat.exe       false.exe    less.exe          ps.exe     tee.exe
> > chmod.exe     find.exe     ln.exe            rmdir.exe  texindex.exe
> > cmp.exe       fold.exe     ls.exe            rm.exe     touch.exe
> > comm.exe      gawk.exe     m4.exe            rxvt.exe   tr.exe
> > cp.exe        grep.exe     make.exe          sed.exe    true.exe
> > cut.exe       gzip.exe     makeinfo.exe      sh.exe     uname.exe
> > date.exe      head.exe     md5sum.exe        sleep.exe  uniq.exe
> > diff3.exe     id.exe       mkdir.exe         sort.exe   vim.exe
> > diff.exe      info.exe     mount.exe         split.exe  wc.exe
> > dirname.exe   infokey.exe  mv.exe            stty.exe   xargs.exe
> > > And how about the existing shell scripts in grass,
> > > do they work with MSYS and GRASS with windows?
> > At moment no because of the problem with variables I reported yesterday,
> > but they will work soon using sh.exe from MSYS.
> What does soon mean, do you provide a new zip archive?
> Or can i handle this?
> Sorry, i have no clue of windows ... or how qgis handles the shell.
Soon means the next week but you don't need to wait for it
because the problem applies only to scripts using g.parser.
Radim
> Best regards
> Soeren
> > Radim
> Analog-/ISDN-Nutzer sparen mit GMX SmartSurfer bis zu 70%!
> Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
