[GRASSLIST:1038] Re: patched rasters
Stuart Edwards sedwards2 at cinci.rr.com
Mon May 8 12:18:13 EDT 2006
Thanks (that's two I owe you, I think)
Your proposed process cleared up the fuzziness nicely but there were
some unintended consequences.  The r.composite image had >32,000 new
'colors'.  I used i.group and i.cluster to sample the data back to
something reasonable.  255 was an improvement, but still too hard to
match a color table.  Using 4 categories (the original map was
printed in blue, brown and black on white) was a big improvement, but
the brown and blue were indistinguishable.  Long story short, I went
back to a graphics program to patch the two sheets and then
reimported them.  Simple really.  Lesson learned is that patching
scanned color graphics is better accomplished in something other than
GRASS as a pre-process!
Stuart
_________________
On May 7, 2006, at 4:48 AM, Maciek Sieczka wrote:
> On Sat, 6 May 2006 10:24:03 -0400
> Stuart Edwards <sedwards2 at cinci.rr.com> wrote:
>> Hi
>> Curious problem with r.patch.  I'm patching two topo maps and which
>> ever one is identified second will appear blurred on the new
>> composite image (see patch1). However, if I display them
>> independently on the same monitor, both maps are just fine (see
>> display1).  It looks like a resolution problem,
> The problem is palette. Your images have indexed palettes (8 bit?),
> each
> palette is different. You would need to:
> 1. move your maps to a truecolor space
> 2. patch
> 3. transform back to indexed (to reduce the size and for Grass display
> sake, which is slow on more than 15 bit color).
> Maybe do it this way:
> 1. separate each maps R,G,B component with r.mapcalc # operator:
> 'map_blue=b#map'
> 2. r.patch R, G and B layers separately
> 3. r.composite them
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie
> tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
