[GRASS-user] [GRASSLIST:1087] Re: GRASS on Win98. Out of environment space. GRASS Monitor not opening
Jachym Cepicky jachym.cepicky at centrum.cz
Wed May 31 03:43:32 EDT 2006
AFAIK GRASS can run only or Windows NT+ (2000, XP, 2003)
Jachym
On Tue, May 30, 2006 at 09:21:51PM -0700, Rochelle MIranda wrote:
> Hello GRASS users
>  I have recently installed GRASS6 on win 98 systems using the
> cygwin environment by creating a CD from iso file. It works fine on all systems.
>  however on one of the system it doesnt work fine.
>  i get the following error
>  "Out of environment space"
>  Also all the GRASS commands works fine.
>  But d.mon  doesnt open up a monitor.
>  It opens the monitor only for a split second
> and then the monitor closes.
>  Kindly help
>  I read archives to find the following
>  - Click on the MS-DOS prompt icon to get a shell window.
> - Click on the fifth button from the left--the one that has a
>  "Properties"
>  tool tip when you hover over it with the mouse.
>  - Click on the "Memory" tab.
>  - In "Initial Environment", change the selection from "Auto"
>   to "4096" - Click "Ok".
>  - You'll get a warning dialog "The changes made to memory setting(s)
>  will not take effect until you restart the program". Click "Ok" to dismiss that dialog.
>  - Close the shell window.
>  - Click on the MS-DOS prompt icon again to get a new shell window. Run
>  BlueJ from that window.
>  - From now on, all new shell windows will have the increased environment
>  space.
> Pls send any  suggestions to make my GRASS monitor open
> and also to remove the out of environment space error
> Rochelle
> Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls.  Great rates starting at 1¢/min.
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060531/c25611ae/attachment.bin
