[GRASS-user] does v.surf.idw raster surface pass through input
	points?
    Luigi Ponti
    lponti at infinito.it
    Wed Nov  1 17:37:28 EST 2006
Hello,
I am trying to fill missing data in daily temperatures via v.surf.idw
interpolation. I have imported daily temperatures via v.in.ascii to a
latlong location, with missing values indicated by "", as suggested by
Hamish:
http://www.intevation.de/rt/webrt?serial_num=2763&display=History
Then I have v.surf.idw interpolated the vector point values, both in the
latlong import location and in a Lambert Conformal Conic (LCC) location,
uploading raster values at positions of vector points to the attribute
table via v.db.addcol & v.what.rast.
Following is an excerpt of the attribute table I have obtained, where
TEMP is the daily temperature at a particular LON and LAT, while SURF1
and SURF2 are values uploaded from interpolated raster in the latlong
and LCC locations, respectively (I have added the MISSING flag to
indicate a missing temperature value, which is a "" in the real table,
for clarity):
CAT | LON | LAT | TEMP | SURF1 | SURF2
1 | 8.283300 | 40.633300 | 14.600000 | 6.585142 | 7.339586
2 | 16.314700 | 40.283100 | MISSING | 11.720935 | 11.169486
3 | 11.850000 | 43.466700 | 12.000000 | 8.832849 | 9.011710
In the help, I read that v.surf.idw generates the interpolated surface
from the data points.
Would this mean that the interpolated raster pass exactly through the
vector input points (i.e., uploaded values should equal original input
values), contrary to v.surf.rst where the smooth paramenter controls the
deviation between the given points and the resulting surface?
Thanks and regards,
Luigi
