[GRASS-user] eliminate some lines
temiz
temiz at deprem.gov.tr
Thu Nov 2 14:46:32 EST 2006
Moritz Lennert wrote:
> temiz wrote:
>> /*hello
>> I couldn't do with v.clean what I wanted to do.
>> I want to eliminate all lines whose their langth are under 20 m.
>> what is the solution ?
> not tested:
> v.to.db map=Original option=length type=line col=linelength units=me
> v.extract input=Original output=Original20 where="linelength>20"
> Moritz
thank you Moritz and Markus
I solved this problem ( grass is really capable).
When I looked at v.to.db, I thought whether I could calculate
the "length of a polygon" as well.
Do you have idea ?
thanks again
Ahmet Temiz
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
