[GRASS-user] GRASS 6.2 / FreeType 2.2 error on Mac OSX
Michael Barton michael.barton at asu.edu
Sat Nov 4 00:01:21 EST 2006
William,
Something I haven't had a chance to report yet. I tried the newest
frameworks yesterday and there is a problem with gdal. Trying to open a tiff
reports an error of incorrect byte order. Reverting to the gdal framework of
a couple weeks back solves the problem.
This is NOT the issue with Daniel's crashes below, but thought you should
know about it if you are looking at the frameworks.
Could Daniel's problem be an incompatibility with 10.3.9?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: William Kyngesburye <woklist at kyngchaos.com>
> Reply-To: William Kyngesburye <kyngchaos at kyngchaos.com>
> Date: Fri, 3 Nov 2006 21:44:17 -0600
> To: Daniel Farnan <DanielF at sharechive.com>
> Cc: "'grassuser at grass.itc.it'" <grassuser at grass.itc.it>
> Subject: Re: [GRASS-user] GRASS 6.2 / FreeType 2.2 error on Mac OSX
> First, how recently did you download the GRASS and frameworks for
> OSX?  A few days ago I made installers for the frameworks so there
> should be no problems installing them.  If you have the non-installer
> frameworks, did you put them into /Library/Frameworks?
> It's possible there is a Panther issue.  I haven't done a whole lot
> of testing for Panther compatibility.
> If it's not a framework installation issue, get back to me and I'll
> see what I can do.
> On Nov 3, 2006, at 8:08 PM, Daniel Farnan wrote:
>> Working on primarily on Debian system with GRASS at work, but still
>> learning, so I put it on My G3 Pismo powerbook, running Panther (now
>> upgraded to 10.3.9). I get the window to come up, congratulations
>> on a great
>> job, and it crashes when I load an old project - this does not show
>> in the
>> terminal. I then started a new location using spearfish data
>> (elevation.dem), which saved as a new mapset, then crashes. I then
>> used the
>> coordiantes to start a new Project with Projection values, and got the
>> error: "Error in startup script: dyld" d.mon can't open library:
>> /Library/Frameworks/FreeType.framework/Versions/2.2/FreeType  ..."
>> A similar string follows in a second error also referring to FreeType.
>> I have downloaded the package (FreeType2 version 2.2.1 was the
>> closest I
>> could find to test) where is GRASS looking to find it? Is there
>> something
>> else to do for OSX?
>> This can wait until Monday(Pacific Time), no line at home, Have a good
>> weekend, and thank you very much developers, hopefully I will have
>> a closer
>> look next week. Thanks, :)Daniel
>>   <<...OLE_Obj...>>
>>  Daniel Farnan, GIS Director
>>  Office phone?415-284-9662
>> grassuser mailing list
>> http://grass.itc.it/mailman/listinfo/grassuser
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
