[GRASS-user] gis.m, d.m and nviz failing
Sat Nov 4 23:15:00 EST 2006
> Henning Lorenz wrote:
> > Yes, that's what I read as well - but this output comes up
> > - if I have the debian gdal package version 1.3.1 installed
> > - if I have compiled gdal 1.3.2 myself
> > I have also checked the symbolic links after compiling/installing
> > the package - everything is in place! The configure script had
> > nothing to complain about gdal-config either ...
> > Hamish wrote:
> >>> libgdal.so.1:
> >> The GDAL libraries can't be found.
> I forgot to mention that the gdal utility programmes work - which I
> wouldn't expect if something is wrong with libgdal. And there are
> symlinks from libgdal.so and libgdal.so.1 to libgdal.so.1.10 which is
> the actual library ...
is the lib dir containing the gdal libs included in  /etc/ld.so.conf?
if not, add it and run ldconfig.
Hamish
