[GRASS-user] Panning and digitising
Sun Nov 5 01:00:16 EST 2006
H.S.Rai wrote:
> If we want to digitise a long feature (say road), then what is the way
> to start digitise, pan it and resume to digitising. I found on doing
> pan, we cannot continue from prevoius work.
> Is there any way to snap to points?
In v.digit, you currently have to digitize as much line as you can in
the current zoom, then pan, digitize more line, pan, etc.
After leaving digitize line mode you can go into "move vertex" mode to
snap the two line ends together. Make sure you gave the two lines the
same category number.
It has been a long time wish to fix this & it should work a bit better
in the next generation digitization tool (wxPython GUI).
these bug reports sound hopeful:
  http://intevation.de/rt/webrt?serial_num=1241
  http://intevation.de/rt/webrt?serial_num=3243
  http://intevation.de/rt/webrt?serial_num=3090
Hamish
