[GRASS-user] grass62/grass63 - broken html
Markus Neteler neteler at itc.it
Sun Nov 5 14:37:08 EST 2006
in fact the specific driver pages are only generated if that
driver is compiled. So far we have static HTML pages, some
"magic" would be needed to construct
lib/db/sqlp/description.html
in dependence of the drivers compiled in db/drivers/.
Help is welcome,
Markus
On Sun, Nov 05, 2006 at 07:10:46PM +0100, Helmut Kudrnovsky wrote:
> hi michele,
> i didn't enable odbc and mysql in the "./configure" step. this is maybe the reason?
> if yes, it would be nice to have this html-links working, because the file "databaseintro.html" (with a lot of general things about db-management in grass) links to them and maybe someone who has not installed all db-drivers (like me) is interested also in this driver-help-pages i.e. for comparing the db-possibilities.
> maybe i can help to fix this....
> regards
> helli
> -----Ursprüngliche Nachricht-----
> Von: michele.rocc at libero.it
> Gesendet: 05.11.06 15:39:25
> An: grassuser at grass.itc.it
> Betreff: Re: [GRASS-user] grass62/grass63 - broken html
> On Sunday 05 November 2006 14:36, Helmut Kudrnovsky wrote:
> (HK)>  hi again,
> (HK)>
> (HK)>  i'looked a little bit more into the broken html-links. i've compiled
> (HK)> from cvs-snapshot 2006-11-04 for grass62 and grass63. (HK)>
> (HK)>  in the grass62 cvs-snaphot 2006-11-04
> (HK)> /usr/local/grass-6.2.1cvs/docs/html/grass-odbc.html existiert
> (HK)>nicht.“
> (HK)> (file not existing) (HK)>
> (HK)> file:///usr/local/grass-6.2.1cvs/docs/html/grass-mysql.html ist
> (HK)>folgender
> (HK)> Fehler aufgetreten: (HK)>  Die Datei oder der Ordner
> (HK)> /usr/local/grass-6.2.1cvs/docs/html/grass-mysql.html existiert
> (HK)>nicht.“
> (HK)> /usr/local/grass-6.2.1cvs/docs/html/grass-mesql.html existiert
> (HK)>nicht.“
> Hi,
> did you enabled odbc and mysql in the "./configure step"?
> Michele
> _______________________________________________________________________
> Viren-Scan für Ihren PC! Jetzt für jeden. Sofort, online und kostenlos.
> Gleich testen! http://www.pc-sicherheit.web.de/freescan/?mc=022222
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
