[GRASS-user] the performance of displaying vector attributes - with MySQL no difference!!
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Nov 13 13:52:17 EST 2006
> Hi again,
> the problem of my database is that I don't see any way to optimize it.
> Imagine if you have 20 thousands of xyz points and want just to
> visualize them in different colors (dem-like color scale). Each point
> has its unique x,y,z values...
> I tried to assign indexes for my "z" column using:
> 	ALTER TABLE my_points ADD INDEX(z_ccordinate);
> And I don't see any difference in performance with e.g. v.univar.sh
> So maybe I am doing something wrong?
> Cheers
> Zbigniew
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
If I understood well from the previous post threre is a RGB column it is
indexed? how much categories of rgb colors you have. If you have as many
categories as values this is the problem. In grass, graphical engine
must assing color and render every pixel individualy
regards
J
