[GRASS-user] importing missing values via v.in.ascii for subsequent interpolation
Luigi Ponti lponti at infinito.it
Tue Nov 14 21:40:02 EST 2006
Hello,
I am trying to import ASCII files with v.in.ascii for subsequent
interpolation via v.surf.idw. The problem is that if I put NULL for
missing values, v.in.ascii complains about the column being of type
DOUBLE and fails. On the other hand if I put missing values as just '',
as suggested at
http://www.intevation.de/rt/webrt?serial_num=2763&display=History
then v.surf.rst seems to use those missing values as ZERO values in
computing the weighted average.
I tried with something like
	v.db.update map=myMap column=myColumn value="NULL" \
		where=myColumn=''
But it did not work.
Does anybody have a way around this?
Regards,
Luigi
