[GRASS-user] file size limit exceeded
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Wed Nov 15 12:09:23 EST 2006
On Monday 13 November 2006 12:23, Martin Wegmann wrote:
> Hello,
> I tried to import a 500 MB DEM using GRASS 6.2 (Debian rep):
> #1
> r.in.gdal -o -k -e
> input=/data2/raster/dem/srtm90_africa_continental_JF/SRTM90_WA_v3/SRTM90_WA
>_v3/hdr.adf output=test
> Over-riding projection check.
> Proceeding with import...
> WARNING: map [test] - unable to write row 14319
> File size limit exceeded
> [Raster MASK present]
> #2
> did it without -e and previously zoomed into the mapset and set the region
> to fit this extend using gis.m functionality (not CLI)
> same error message
> #3
> I found related error messages in the ML hence I installed grass62 and 63
> with LFS but I have some problems compiling with gdal support (another
> e-mail on gda-dev)
just for the archive:
"libgdal.so.1" could not be found even though it was located using  `locate
libgdal` but in /usr/local/lib
hence I added /usr/local/lib/ in
/etc/ld.so.conf and executed "ldconfig"
now import and LFS works.
Martin
> any idea how I can solve this file size limit problem while not yet being
> able to compile 62/63?
> regards, Martin
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
