[GRASS-user] Re: [GRASS-dev] 3D DXF output: howto?
Markus Neteler neteler at itc.it
Thu Nov 16 03:38:33 EST 2006
Hi Benjamin,
(I have taken out grass-dev to avoid too much cross-posting)
Benjamin Ducke wrote on 11/16/2006 09:37 AM:
> Hi everyone,
> I am currently trying to get some 3D points out of GRASS and into a
> 3D modeller (blender.org) fur further processing.
> Two questions arise:
> 1. My GRASS vector points are 2D + elevation attribute. Is it possible
> to map the elevation attribute to a Z coordinate and create a 3D map?
v.drape will do that for you.
> 2. Is it possible to output 3D vector points as 3D DXF?
v.out.dxf seems to set 3D dxf vertices. Doesn't it work?
Markus
