[GRASS-user] 3D DXF output: howto?
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Thu Nov 16 09:51:20 EST 2006
I just loaded a few dozen points with coordinates around 600000
into blender and it worked.
I was able to load the points, select them and zoom into them.
However, the -1000 to +1000 range is still present in some menu widgets
and the navigation outside of it seems difficult.
I also experimented with importing 43.000+ points and after ca. 10
minutes of waiting for the result, I killed the program.
Anyway, my coordinates are local coordinates with a very small range, so
I will  not hit that limit.
Best,
Benjamin
paallen at attglobal.net wrote:
> Benjamin,
> Just one warning.  About 1-2 years ago I too looked at using blender an I discovered a problem.  Blender at that time could only work withe coordinates (x,y, and z ) in the range of +/-10000.00.  Which is a problem for most realworld coordinates.
> Does this limitation still exist?
> Do your coordinates exceed this range?
> Good luck,
> Phillip Allen
> Sent via BlackBerry from Cingular Wireless
> -----Original Message-----
> From: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
> Date: Thu, 16 Nov 2006 09:37:01
> To:GRASS user list <grassuser at grass.itc.it>,       GRASS devel <grass-dev at grass.itc.it>
> Subject: [GRASS-user] 3D DXF output: howto?
> Hi everyone,
> I am currently trying to get some 3D points out of GRASS and into a
> 3D modeller (blender.org) fur further processing.
> Two questions arise:
> 1. My GRASS vector points are 2D + elevation attribute. Is it possible
> to map the elevation attribute to a Z coordinate and create a 3D map?
> 2. Is it possible to output 3D vector points as 3D DXF?
> If not, maybe someone could detail on what needs to be done and I will
> try and hack up something.
> Best,
> Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
