[GRASS-user] Calculating a raster "polygon density" map
Brent Wood b.wood at niwa.co.nz
Mon Nov 20 20:13:19 EST 2006
Matthew Perry wrote:
> Hey folks,
>  I'm trying to rasterize a polygon vector layer as a polygon density
> map. In other words instead of each cell containing NULL or the
> underlying vector attribute (v.to.rast), I'd like each raster cell to
> represent the percent of the cell's area covered by polygons.
> Is there an existing function that can handle this? Has anyone tried
> creating such a polygon density function in GRASS or GDAL/OGR?
> Thanks for the input,
I've recently done a similar exercise with polygons representing the
swept area of commercial fishing trawls and a grid polygon layer.
The "raster" layer is a table of square polygons forming a grid covering
the area of interest.
A simple SQL joins the two tables (400,000 cells & 1,000,000 tow
polygons), giving 5,000,000 records & the intersections of the two
layers, ie: each tow is divided up into the cells it crosses. Given the
output includes cell_id, SQL queries to determine the aggregate swept
area within a cell, which can be many times the cell area, the area of
each cell which has or has not been fished, etc are trivial & pretty fast.
So my solution was not a raster one as you suggest , but used a vector
layer of cells which functioned in a similar way. It is then trivial to
get the data into GRASS (for you) or GMT & R (for me :-) using a XYZ
dataset of grid centroids & whatever Z value I want to use
Cheers,
  Brent Wood
