[GRASS-user] calculate pixel areas with starspan
maning sambale emmanuel.sambale at gmail.com
Wed Nov 22 23:15:41 EST 2006
commands goes like tihis
#extract number of pixels by class, vector is a municipality shapefile
raster is grass raster
 starspan --vector /home/maning/data/ciPhimuni/ciphimuni.shp --raster
/home/maning/data/manilageog/sealevel3/cellhd/rise_5_reclass --fields
MUNICIPALI --count-by-class /home/maning/data/stat/rise_5_class.csv
--noColRow --noXY --progress
#get statistics
MUNICIPALI --stats /home/maning/data/stat/rise_5_stats.csv avg mode
stdev min max --noColRow --noXY --progress
How do I compute class areas for each polygon?
Cheers,
Maning
On 11/21/06, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> On Sunday 19 November 2006 21:53, maning sambale wrote:
> > Hi,
> > I have grass rasters and I want to calculate raster classes based on
> > the attributes of a shapefile.  I'm experimenting with starspan and so
> > far its extremely fast than:
> > v.in.ogr #to export shapefile
> > v.build and v.digit #to check for topology problems
> > v.to.rast
> > r.report
> > But, how can I get area coverage (in percent and hectares) from a
> > given raster class in a polygon?
> > Any ideas?
> > Cheers,
> > Maning
> Hi Manning,
> How are you invoking starspan, and what exactly do you mean by "an area
> coverage" ?
> You might check out the "mini-raster" options in starspan:
> --mini_rasters <prefix>
> --mini_raster_strip <filename>
> I believe that these will extract "mini" rasters for each vector feature. Be
> sure to read the documentation however.
> Cheers,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com|
| _)_/LI  |http://www.geocities.com/esambale/philbiodivmap/philbirds.html   |
