[GRASS-user] v.clean tool=prune - 'thresh' interpreted wrong?
Hamish
hamish_nospam at yahoo.com
Mon Oct 2 22:05:18 EDT 2006
Maciej Sieczka wrote:
> There is a line:
> $ echo "L 4 1
> 10 10
> 20 10
> 30 10
> 40 10
> 1 1" | v.in.ascii -n out=line format=standard
> So there are 4 vertices and the distance between each 2 following is
> 10. Then I don't understand why the:
> $ v.clean input=line output=line_pruned type=line tool=prune
> thresh=1
> removes ALL the vertices!:
> $ v.out.ascii line_pruned format=standard
> ORGANIZATION:
> DIGIT DATE:
> DIGIT NAME: shoofi
> MAP NAME:
> MAP DATE: Mon Oct 2 20:51:52 2006
> MAP SCALE: 1
> OTHER INFO:
> ZONE: 0
> MAP THRESH: 0.000000
> VERTI:
> L 2 1
> 10 10
> 40 10 <- WHY ARE THE TWO OTHER GONE ???
> 1 1
> I declared thresh=1, the distance between vertices is 10 - so none
> should be removed, but all are! And the same happens with all the lower
> thresholds until thresh=0.03.
> v.clean man says: "prune: remove vertices in threshold". Maybe I don't
> understand what the threshold means in this case?
what if there is some angle between the points? e.g.
G6> v.in.ascii -n out=line format=standard << EOF
L 4 1
10 10
20 5
30 7.5
40 10
1 1
EOF
Hamish
