[GRASS-user] RE: [GRASS-dev] Can't create locations using EPSG codes
Patton, Eric epatton at nrcan.gc.ca
Fri Oct 13 11:44:35 EDT 2006
One thing that I just noticed is that my epsg file isn't in the standard
location as the default path of /usr/local/share/proj/epsg given in the
Grass startup screen. My epsg is in /usr/share/proj/epsg - but I specify
this path to the startup window, so it should just get passed verbatim.
Could that make any difference?
~ Eric.
-----Original Message-----
To: 'Maciej Sieczka '
Cc: ''grassuser at grass.itc.it' '; ''grass-dev at grass.itc.it ' '
Sent: 10/13/2006 11:37 AM
Subject: RE: [GRASS-dev] Can't create locations using EPSG codes
Maciek,
Thanks for testing this. I wonder what could be causing the problem for
me
then? I'm at a complete loss to explain this. I'm using today's cvs. I
have
gdal 1.3.2 and the gdal-grass 1.3.1 plugin installed, it that makes any
difference.
~ Eric.
To: Patton, Eric
Cc: 'grassuser at grass.itc.it'; 'grass-dev at grass.itc.it '
Sent: 10/13/2006 11:21 AM
Subject: Re: [GRASS-dev] Can't create locations using EPSG codes
Patton, Eric wrote:
> Trying to create a new location from the Grass intro screen, using
EPSG code
> 2036 (New Brunswick Double Stereographic)gives the following error:
> child process exited abnormally
> Can anyone reproduce this error for me? I'm using Ubuntu 6.06.
On the same Ubuntu it works for me, uisng 6.3 CVS 2006-10-11. The
location created is:
GRASS 6.3.cvs (test2):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
proj       : sterea
a          : 6378137
es         : 0.006694380022900787
lat_0      : 46.5
lon_0      : -66.5
k          : 0.999912
x_0        : 2500000
y_0        : 7500000
towgs84    : 0,0,0,0,0,0,0
no_defs    : defined
-PROJ_UNITS------------------------------------------------
unit       : metre
units      : metres
meters     : 1
Maciek
grass-dev mailing list
http://grass.itc.it/mailman/listinfo/grass-dev
