[GRASS-user] r.in.xyz: Could open text file ~ 2.5GB
Patton, Eric epatton at nrcan.gc.ca
Thu Oct 19 13:46:28 EDT 2006
Disregard. I posted this email before Gylnn's answer about LFS in r.in.xyz.
I've split the files into 1GB pieces as a workaround.
~ Eric.
-----Original Message-----
To: 'grassuser at grass.itc.it'
Sent: 10/19/2006 1:19 PM
Subject: [GRASS-user] r.in.xyz: Could open text file ~ 2.5GB
I'm trying to open a text file to scan for extents:
r.in.xyz -s input=2006MB_GarryTrough_1N.txt output=2006MB_GarryTrough_1N
method=mean type=FCELL fs=space  x=1 y=2 z=3 percent=100
Could not open input file
</home/epatton/Projects/Whalen/PERMANENT/WORK/2006MB_GarryTrough_1N.txt>
I get the same error regardless of what percent parameter is set to (60,
40,
10). Is this an LFS problem with r.in.xyz?
~ Eric.
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
