[GRASS-user] r.watershed hangs
H.S.Rai hardeep.rai at gmail.com
Mon Oct 23 11:27:56 EDT 2006
On 10/23/06, Charles Ehlschlaeger <c.ehlschlaeger at insightbb.com> wrote:
> The solution is to include a more realistic threshold size. Ask yourself
> "what is the smallest watershed basin you want to consider?" If the answer
> is 10,000m^2, and grid cells are 10x10m, then threshold should be set to
> 100.
With 100 value, it worked fine. Thank you very much. I was trying to
learn from tutorial bases on GRASS_5, on GRASS_6. There there was
option was units, that might have taken care of this thing.
With kind regards,
