[GRASS-user] Installation problem
gotnidea! Business Development Centre gotnidea at gmail.com
Fri Oct 27 01:04:23 EDT 2006
Thanks again Moritz,
I changed the address of postgres link in grass bat file file to my d:
postgres installation. GRASS is opening now.
I would now work on some tutorials and get back if I require any help.
Thanks again
Abhinav
On 10/26/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> switched this to wingrass list...
> gotnidea! Business Development Centre wrote:
> > Thanks Moritz
> > I have installed postgresql on my D: ( NTFS one).
> > Now I have one more problem. I searched it over mailing list
> > archives. It is quite similar to the one at:
> > http://www.nabble.com/grass-not-starting-tf2417646.html#a6739510
> Dilnesaw Alamirew wrote:
> > 1) pop-up window:
> > error in startup script
> > can't read "parts(n)": no such variable while executing
> > "MapCanvas::zoom_new $mon $parts(n) $part(s) $parts(e) $parts(w)
> > $parts(nsres) $parts(ewres)" (procedure "MapCanbas::zoom_greion" lin
> > 11
> > line 40, line 11, line 69, line 30 mentioned. Unfortunately the error
> >  message could not be copied.
> This normally means that pg.dll cannot be found and that g.proj fails.
> Is PostgreSQL correctly installed ? Is the path to it correctly defined
> in grass.bat ?
> > 2) shell: STARTIN GRASS ....
> > Warning: Attention! Warning: Look is not supported onWindows!
> > I have a GRASS shell but no GUI.
> Do you see any other error message ? The warnings have nothing to do
> with this.
> > If I define a new location/mapset I get syntax error after "short
> > description" promot - input not recognised, even though it is mainly
> >  only y or n.
> > If I define a new location/mapset from a georeferenced file I get:
> > Application error: channel console 2 wasn't opened for writing.
> Currently definition of new location from georeferenced file or from
> projection values does not work in wingrass.
> > The only problem is that I couldn't get any workable solution. I am
> > working on spearfish data. I would love if any one could guide me to
> > any tutorial on the same.
> Which of the above problems do you have ? Please describe exactly what
> you do and what error messages you see.
> Moritz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061027/0d3f24fd/attachment.html
