[GRASS-user] problem exporting maps using ps.map
Luca Penasa
luca.penasa at email.it
Mon Oct 30 07:14:35 EST 2006
Moritz Lennert wrote:
> Luca Penasa wrote:
>> im trying to export a map using the ps.map command...
>> im using grass 6.3 from cvs and the output is;
>> WARNING: Data exists after final 'end' instruction!
> here's the problem: you have an end somewhere where you probably
> shouldn't and so it does not take into account any subsequent commands.
> If you need more help you should post your ps.map instructions file.
> Moritz
i solve this deleting an 'end' at eof. but the problem is this:
PS-PAINT: scale set to 1 : -168897.
PS-PAINT: reading raster file <mappa in licheni> ...
PS-PAINT: reading labels file <ibl in licheni> ...
PS-PAINT: reading vector points file <sites_203 in licheni> ...
PS-PAINT: reading text file ...
*ERROR: PSmap: do_scale(): shouldn't happen *
