[GRASS-user] chamelon-GRASS application site with URL
Pericles S. Nacionales pnaciona at gis.umn.edu
Fri Sep 1 12:57:55 EDT 2006
Very cool!  Thanks for sending the link.  You should also put it in the
MapServer Gallery, if you haven't done it yet.
The response seems reasonable (maybe a little slow).  The watershed
statistics are returned pretty fast.  It would be interesting to see
this on a more capable hardware.
-Perry
Massimiliano Cannata wrote:
> Hi all,
> I would like to inform you that a demo site is now on-line to see how
> GRASS is run trough Chameleon.
> For instruction on how to use it, you can click the Help button.
> The URL is: http://195.176.186.207:8002/chameleon/envca/
> Could you try to check if everything is working and eventually give me a
> feedback?
> (It could result not too fast in map loading due to the low hardware
> configuration of the server)
> As soon as possible I will add a page with more technical details on how
> to set up such a link.
> Thanks,
> and hope to see you in Lausanne.
> Massimiliano
