[GRASS-user] Re: [GRASS-dev] MS-Windows native GRASS
Huidae Cho grass4u at gmail.com
Sun Sep 17 17:27:08 EDT 2006
On Sun, Sep 17, 2006 at 08:32:04PM +1200, Hamish wrote:
> Huidae Cho wrote:
> > Did you try to run c:\msys\1.0\msys.bat and check if PATH includes
> > /mingw/bin?  /mingw/bin should be there by default.  I think you
> > installed MSys before MinGW so that MSys does not know about MinGW.
> > This is why I emphasized installation order.
> could your install script test if this has been done, and maybe
> something like:
> echo "PATH=%PATH%;/mingw/bin" >> c:\msys\1.0\msys.bat
> if needed?  (or just print a warning)
Just updated.
Thank you.
Huidae
