[GRASS-user] v.in.db and dbf-tables SQL parser error
Wolfgang Qual Wolfgang.Qual at gmx.net
Wed Sep 20 03:30:35 EDT 2006
Good morning, GRASS-users,
I encountered a problem when using v.in.db with dbf-tables.
GRASS 6.1.cvs (muc_intra):~ > v.in.db driver=dbf database=./ table=2006_07_linux x=Quer y=Hoch key=Idcol out=sender47
DBMI-DBF driver error:
SQL parser error in statement:
select Idcol, Quer, Hoch from 2006_07_linux
Error in db_open_select_cursor()
ERROR: Cannot open select cursor: 'select Idcol, Quer, Hoch from
       2006_07_linux'
I checked the columns in OpenOffice - all named columns in the grass-command where of type numeric with no decimal places. The funny thing is that the same command worked perfectly with another table (this table contained only few records).
At the moment, I do not know, what could cause this error - maybe someone else encountered the same problem? Ideas are more than welcome!
Best regards,
Wolfgang
NEU: GMX DSL Sofort-Start-Set - blitzschnell ins Internet!
Echte DSL-Flatrate ab 0,- Euro* http://www.gmx.net/de/go/dsl
