[GRASS-user] v.digit ERROR: Cannot open toolbox:
Wed Sep 20 15:09:26 EDT 2006
Ulrich Leopold wrote:
> >> But when I start v.digit with the following commands I get the following error
> >> message:
> >> What does it mean exactly? What can be the problem?
> > The error means that it couldn't execute the Tcl/Tk script
> > $GISBASE/etc/v.digit/toolbox.tcl, either because the file isn't
> > present, or an error occurred while executing the file.
> And how can I solve this problem. The file is present. But soemhow it cannot
> be executed:
> GRASS 6.2.0beta3 (Lux):~ > $GISBASE/etc/v.digit/toolbox.tcl
You can't run it as a standalone script. It has to be read into the
custom Tcl interpreter in v.digit.
Try running it via wish, e.g.:
	wish $GISBASE/etc/v.digit/toolbox.tcl
You should get the error:
	Error in startup script: invalid command name "c_tool_centre"
If you get some other error, it's a problem with the script, otherwise
it's a problem with v.digit's use of Tcl/Tk.
