[GRASS-user] gdal and grass new problem from "is, but isn't" series
Huidae Cho grass4u at gmail.com
Thu Sep 21 03:41:42 EDT 2006
On Thu, Sep 21, 2006 at 02:28:45AM -0500, Huidae Cho wrote:
> On Thu, Sep 21, 2006 at 09:25:18AM +0200, Jarosław Jasiewicz wrote:
> > Hi
> > gdal 1.3.2 and 1.3.1 grass 6.3 cvs (newest), Kubuntu 6.06 and ubuntu 6.06 with
> > added KDE
> > after compilation of gdal over grass (without erros and warnings) when I try to
> > run gdalinfo (or some other gdal utilities) message appears:
> > gdalinfo: error while loading shared libraries: libgrass_vect.so: cannot open
> > shared object     file: No such file or directory
> > of course libgrass_vect.so exist in /usr/local/grass6.3.cvs/lib/ as symlink to
> > libgrass_vect.cvs.so
> Check if your PATH includes /usr/local/grass6.3.cvs/lib.
Did I say PATH?  Sorry, it's LD_LIBRARY_PATH.  If you cannot find the path,
add the following lines to your ~/.profile or ~/.bash_profile:
LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/local/grass6.3.cvs/lib"
export LD_LIBRARY_PATH
Huidae
> Huidae
> > regards
> > Jarek
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
