[GRASS-user] nviz segfault
cliff clifferson c-cain at gmx.net
Thu Sep 21 15:51:15 EDT 2006
System: freebsd 6.2
Grass 6.2 from trento site
Hello,
i have a problem using nviz on vector data.
here is what i do:
v.in.ascii (reading in a textfile which contains only x y z values, nothing more)
g.region vect=test
nviz vect=test
whenever running nviz from commandline it says:
Error: No lines from test fall into current region
Total vect memory = 0Kbytes
then nviz segfaults
i get this behavior for different inputs which i took from grass tutorials
too, what am i doing wrong?
Thanks,
Nico
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
