[GRASS-user] Error importing DMS into standard format usingv. in.ascii
Patton, Eric epatton at nrcan.gc.ca
Wed Sep 27 11:18:54 EDT 2006
Trying again after converting DMS to deciaml degrees:
echo "L 4 1
66.5W|44.25N
66.0W|44.25N
66.0W|44.0N
66.5W|44.0N
1 1 " | v.in.ascii -n output=DMS_test format=standard  --o
Error reading ascii file:
66.5W|44.25N
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes     :   0
Number of primitives:   0
Number of points    :   0
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
The above command also fails if the coodinates are given to 6 decimals
places, which probably doesn't even matter.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: 'grass-dev at grass.itc.it'; 'grassuser at grass.itc.it'
Sent: 9/27/2006 11:03 AM
Subject: Re: [GRASS-user] Error importing DMS into standard format
usingv.in.ascii
Patton, Eric wrote:
> Following the example given in
http://article.gmane.org/gmane.comp.gis.grass.devel/8368/match=v+in+asci
i+dms
> I'm trying to import D:M:S coordinates into a Lat-Long Location to
create a
> line vector:
> echo "L 4 1
> 66:30:00W|44:15:00N
> 66:00:00W|44:15:00N
> 66:00:00W|44:00:00N
> 66:30:00W|44:00:00N" | v.in.ascii -n output=test format=standard
Looking at the code, I see that DMS is only supported for
format=points; format=standard requires decimal values.
