[GRASS-user] Re: Cygwin Grass 6.2 compiling?
Tomas Lanczos lanczos at t-zones.sk
Wed Sep 27 18:01:58 EDT 2006
> [mailto:grassuser-bounces at grass.itc.it] On Behalf Of Luigi Ponti
> Glynn Clements wrote:
> > Luigi Ponti wrote:
> >> Has anyone found a way to compile grass 6.2 on cygwin?
> > Use --disable-shared. Shared libraries used to work on Cygwin, but
> > they stopped working following a Cygwin update a few months back.
> Hello,
> I am trying to compile grass-6.1.0 on Cygwin. Using the command:
>     $ ./configure --disable-shared>configure.log
> I get the following warnings/error:
>     configure: warning: *** External PROJ.4 directory not specified
>     configure: warning: *** Unable to locate PROJ data files.
>     configure: error: *** Unable to locate PNG includes.
> Along with the configuration log below. It is a Cygwin
> installation where grass6.1.cvs (April 17, 2006) is arleady
> installed and running ok.
> What am I missing?
If the proj4 is installed maybe You should specify it's (and/or includes,
libraries,) location after for configuring, the same for the PNG includes.
Check also the header files.
Tomas
> Thank you and regards,
> Luigi
_____________________________________________
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
