[GRASS-user] database(s) in grass
Markus Neteler neteler at itc.it
Thu Apr 12 04:11:48 EDT 2007
On Thu, Apr 12, 2007 at 08:38:52AM +0100, Ricardo Oliveira wrote:
> On Wed, 11 Apr 2007 20:20:26 +0200
> Markus Neteler <neteler at itc.it> wrote:
> > 1. do
> > # example for storing DB in mapset directory (keep single quotes):
> > db.connect driver=sqlite
> > database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db' db.connect -p
> Using this approach the result is: "no such file"
So, you do:
db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
and then
db.connect -p
and it says "no such file"? Are you sure? What is the *exact*
error message? Cannot find a "no such file" message in the
db.connect program, nor sqlite driver, nor DBMI interface.
The db.connect does not create the file. It just sets the connection.
What does
db.connect -p
report?
> > 2. do
> > v.digit -n newmap
Did you do this *after* running db.connect?
This command will create sqlite.db and the table if you use the
"settings" tab in v.digit to do so.
I suggest that you try in a new mapset.
Markus
