[GRASS-user] NVIZ max res ppm = reboot!
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Tue Apr 17 17:14:46 EDT 2007
That's what i've been doing. The problem arises when I need to produce
a high-quality 3D output for a publication. At least 6.2 is working,
so, when needed, I'll use it.
Carlos
On 4/17/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> "Carlos \"Guâno\" Grohmann" wrote:
> > > > yesterday, working with the last cvs, when I tryed to export a NVIZ
> > > > view with max.res. ppm, my machine rebooted! it worked fine in 6.2
> > > > deb.
> > > Try:
> > >         export GRASS_NO_GLX_PBUFFERS=1
> > >         export GRASS_NO_GLX_PIXMAPS=1
> > > Unfortunately, a number of OpenGL drivers claim to support pBuffers
> > > and/or GLX Pixmaps then crash (sometimes quite horribly) if you
> > > actually try to use them.
> > nope. rebooted again.
> In that case, you'll just have avoid using the "max res PPM" option.
> OpenGL crashes are mostly beyond our control.
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
