[GRASS-user] Question about databases and vector files...
Jonathan Greenberg greenberg at ucdavis.edu
Thu Apr 26 11:09:26 EDT 2007
Hmm, good question -- mostly I'm wondering about the use of v.in.ogr for a
huge shapefile (3 million + points with about 6 attributes per point) -- the
dbf driver seems to either stall or crash (depending on the installation of
grass) -- if I establish pg as the driver, will it use pg to import as well?
--j
On 4/26/07 7:24 AM, "Dylan Beaudette" <dylan.beaudette at gmail.com> wrote:
> On 4/26/07, Hamish <hamish_nospam at yahoo.com> wrote:
>> Jonathan Greenberg wrote:
>>> Will all v.XXX commands work on vector files regardless of which
>>> database is hosting the files?  E.g. if I have a point file that is in
>>> a postgis DB, can I use commands such as v.buffer (and also have the
>>> results put back into a postgis format)?
>> yes, they should.
>> Hamish
> Hi,
> Hamish: are your refering to the attributes or the geometry? I was not
> aware that GRASS can operate directly on postgis geometry.
> Dylan
Jonathan A. Greenberg, PhD
Postdoctoral Scholar
Center for Spatial Technologies and Remote Sensing (CSTARS)
University of California, Davis
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307 at hotmail.com
