[GRASS-user] r.reclass and g.remove: another issue
Thu Apr 26 19:04:52 EDT 2007
Glynn Clements wrote:
> > The problem is beacause:
> > in:
> > ~/spearfish60/nowe/cell_misc/abc
> > exist file reclased_to with "cdf at nowe"
> > if reclased_to will be removed manually base map can be removed without
> > problem. Unfortunatly I don't how to fix it
> The first g.remove should have removed the entry from the reclassed_to
> file; I'll look into why it didn't.
The code was unconditionally appending @mapset to the name, looking
for e.g. cdf at nowe@nowe in the reclass_to file.
Fixed in CVS.
