[GRASS-user] Question about databases and vector files...
Michael Perdue michael_perdue at yahoo.ca
Fri Apr 27 11:28:44 EDT 2007
On both of my 32 bit machines (Mac OSX 10.4.9 and SuSE 10.1) I can
get about 60 - 70 million points imported before it conks (I don't
recall the exact message but it was something about an overflow...
negative file offset). The coord file is right around 2GB when the
error message is received. I was using the -z flag in v.in.ascii so I
imagine one might be able to get significantly more in without the
3rd dimension.
cheers,
Mike
On 27-Apr-07, at 5:59 AM, Markus Neteler wrote:
> Jonathan Greenberg wrote on 04/26/2007 07:31 PM:
>> As I said -- lots of newbie questions here (I'm a raster man, just
>> now
>> beginning to learn the intricacies of vector files beyond "hey,
>> it's a bunch
>> of points") -- is there any inherent size limitation for vector
>> files (the
>> geometry portion) in grass?
> As far as I remember, Helena imported up to 500 million points - but
> without topology (via
> v.in.ascii -b ...). As Glynn said, the 2GiB limit is one problem
> unless
> LFS is working for
> vector data, too.
>>  E.g. should I be fine with the points I've
>> described if I use the pg to deal with the database portion, as
>> opposed to
>> the standard dbf driver?
> Maybe you can give it a try and report back?
> Markus
> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
> ITC -> since 1 March 2007 Fondazione Bruno Kessler
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
