[GRASS-user] HDF5 library conflict between R 2.4 and GRASS 6.2:
Rick Reeves reeves at nceas.ucsb.edu
Fri Apr 27 11:40:32 EDT 2007
Greetings:
When using R within GRASS6, and loading the rgdal library, I encounter
an error
loading a specific version of the HDF5 library that does not occur when
I perform
the same operation in R 'outside' of GRASS6:
Here is a record of the error on my ubuntu system:
----------  Start ---------
reeves at wallace:~$ grass2
Cleaning up temporary files.....
Starting GRASS ...
Welcome to GRASS 6.2.1 (2006)
GRASS homepage:                          http://grass.itc.it/
This version running thru:               Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter:                exit
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
GRASS 6.2.1 (spearfish60):~ > R
R version 2.4.1 (2006-12-18)
Copyright (C) 2006 The R Foundation for Statistical Computing
ISBN 3-900051-07-0
R is free software and comes with ABSOLUTELY NO WARRANTY.
You are welcome to redistribute it under certain conditions.
Type 'license()' or 'licence()' for dGRASS 6.2.1 (spearfish60):~ > R
ISBN 3-900051-07-0
Type 'license()' or 'licence()' for distribution details.
 Natural language support but running in an English locale
R is a collaborative project with many contributors.
Type 'contributors()' for more information and
'citation()' on how to cite R or R packages in publications.
Type 'demo()' for some demos, 'help()' for on-line help, or
'help.start()' for an HTML browser interface to help.
Type 'q()' to quit R.
[Previously saved workspace restored]
 > library("rgdal")
Loading required package: sp
Error in dyn.load(x, as.logical(local), as.logical(now)) :
       unable to load shared library
'/usr/local/lib/R/site-library/rgdal/libs/rgdal.so':
 libhdf5-1.6.4.so.0: cannot open shared object file: No such file or
directory
Error: package/namespace load failed for 'rgdal'
 > library("rgdal")
directory
-------------------------   Trying the same thing Outside of GRASS
reeves at wallace:/usr$ R
ISBN 3-900051-07-0
 > library("rgdal")
Geospatial Data Abstraction Library extensions to R successfully loaded
----------  End ---------
Would anyone have any suggestions?
I tried to find the 'missing' hdf5 library: libhdf5-1.6.4.so.0: in the
archives, to no avail.
Thanks, Rick Reeves
Rick Reeves
Scientific Programmer / Analyst
National Center for Ecological Analysis and Synthesis
UC Santa Barbara
www.nceas.ucsb.edu
805 892 2533
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070427/d23a5e38/reeves.vcf
