[GRASS-user] Qgis per Windows: problemi con r.out.gdal
G. Allegri giohappy at gmail.com
Sat Dec 1 06:28:01 EST 2007
Hi Markus,
the pc I was using has Qgis 0.9.0.26 for Windows.
The raised error is
"ERROR 6: SetColorTable only supported for Byte or UInt16 bads in Tiff format".
I get the same with r.out.gdal from Grass on my Ubuntu.
The resulting tiff appears uncorrect, with lot of blank areas...
This is what I get in coth cases:
http://www.geospatial.it/allegri/img/aspect_out.JPG
If I try with r.out.tiff it alerts me that decimal values will be
rounded to integer values, but the otuput seams correct...
Giovanni
> > Sto usando il pc di un collega, che ha installato Qgis per Windows. Ci
> > sono
> > dei problemi con l'r.out.gdal lanciato dalla shell msys.
> > Viene chiesto come parametro type di uscita o Byte o UInt16 (Float32 mi
> > restituisce errore) e il tif generato è illeggibile in altri gis, eccetto
> > Qgis stesso.
> > Ne sapete qualcosa?
> > Giova
> Hai scritto alla lista in italiano :)
> Which QGIS version do you use? That's essential to know.
> Which error do you get with Float32?
> Note that I have fixed GeoTIFF color tables in r.out.gdal in
> 6.3.0RCx (which will hopefully reach QGIS 0.9.1 for Windows/Mac).
> Markus
> View this message in context: http://www.nabble.com/Qgis-per-Windows%3A-problemi-con-r.out.gdal-tf4923752.html#a14103145
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
