[GRASS-user] Correction of terrain effects for MODIS data?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sat Dec 1 15:03:42 EST 2007
Hi!
Will this approach enable a correction for terrain as well? I don't see
how I can incorporate elevation data or anything relevant.
I used the cosine correction approach which is described in GRASS-GIS in
order to correct a MODIS image. But the result is over-corrected (!) as
mentioned also in the book.
I am looking for a practical approach in order to minimize terrain
effects in a MODIS NIR surface reflectance acquisition. The area in
which I am interested to visually identify the land cover, is
mountainous. So any correction would be of great importance.
Thank you in advance.
On Fri, 2007-11-30 at 15:10 -0800, Hamish wrote:
> Nikos Alexandris wrote:
> > I tried to follow the example for correction of terrain effects in a MODIS
> > surface reflectance NIR band
> > (...as far as I know, MODIS surface reflectance imagery is only corrected
> > for atmospheric effects).
> > I don't get the desired results... The output is too bright from what one
> > would expect it to be.
> > Any recommendations?
> I've never used it for MODIS, but you could try i.landsat.rgb to see if that
> helps. (it wants three 0-255 bands, it doesn't care about it being LANDSAT or
> not)
> Hamish
>       ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071201/8bf63501/attachment.bin
