[GRASS-user] GRASS6.2.1+QGIS0.9_db.connect
Jonathan Aguero jua130 at psu.edu
Sun Dec 2 10:54:30 EST 2007
I experienced something like that a few weeks ago. Is windows your OS?
Any way, I just edited the VAR file in my mapset to remove the last two
lines:
 schema:(null)
 group:(null)
It worked the next time I opened GRASS or QGIS in that mapset.
----- Original Message -----
To: <grass-user at lists.osgeo.org>
Sent: Saturday, December 01, 2007 5:26 PM
Subject: Re: [GRASS-user] GRASS6.2.1+QGIS0.9_db.connect
> Markus Neteler wrote:
>> what does
>> db.connect -p
>> report  (print current settings)?
>> You could set to a different driver:
>> http://grass.itc.it/grass63/manuals/html63_user/db.connect.html
>> Markus
> Thanks for reply
> db.connect -p:
> driver:pg
> database:host=localhost,dbname=cms
> schema:public
> group:(null)
> I tried to change to:
> driver:dbf
> database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> schema:(null)
> group:(null)
> but import module get me this error:
> Table '(null).bacini' linked to vector did not exist.
> Layer: bacini
> DBMI-DBF driver error:
> SQL parser error in statement:
> create table (null).bacini (cat integer, ID double precision, GEOMETRY_S
> varchar ( 254 ), AREE varchar ( 254 ), NOME varchar ( 254 ))
> Error in db_execute_immediate()
> Cannot create table: create table (null).bacini (cat integer, ID double
> precision, GEOMETRY_S varchar ( 254 ), AREE varchar ( 254 ), NOME varchar
> 254 ))
> What you think about it?
> http://www.nabble.com/GRASS6.2.1%2BQGIS0.9_db.connect-tf4928891.html#a14110345
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
